Dual Plate Wafer Type Check Valve Diameter
hello
Outside diameter of all wafer type check valves (Dual Plate) are more than diameter of bolt circle (ASME B16.5) so, what kind of flanges are used for installing these valves between them?
thank you
thank you
RE: Dual Plate Wafer Type Check Valve Diameter
