Overlap/Doc on Second Monitor grayed out
3
Anyone know why my Overlap on Second Monitor and Doc on Second Monitor options, in the Resource Bar, are grayed out?
I'm pretty excited this functionality was added in NX 10, but for some reason my is grayed out and I cannot figure out why despite looking, seemingly, everywhere.
Sean
RE: Overlap/Doc on Second Monitor grayed out
You are using the new Ribbon interface? (not switched back to Pre NX9 toolbars)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
- and... you are connected to two monitors when you check this ?
Tomas
1) I am using the ribbon toolbar's (post-NX 9 interface).
2) Currently, I have my Navigators manually Undocked and placed on the second monitor, so I am connected to two monitors.
This option is available for other users here so I figure it's a setting in Customer Defaults but I haven't had any luck...
I do not think it's a customer default. I have only seen when I left-click the gearwheel in the Resource Bar.
( note, Left-click not Right click.)
Are your monitors "similar" ? ( same resolution etc ?)
I noted that if I have the monitors arranged ( in the Windows "Screen Resolution") dialog on top of each other, the option will not appear. As soon as I move the second monitor to the right or left from the primary , it appears.
Tomas
Ahh.., Toost you're the man,
That seems so weird to me, but you're right - when I reversed the Primary monitor it became selectable...
Thank you!
Sean
