NX Initialization Error for NX 9 Teamcenter 10
Getting the following error when trying to start NX from Teamcenter. "Runetime Exception in SOA client from the object type UGS::PDM::MODEL:CDM:USER AsG9BSnq4twC: Type Mismatch asking for Char Array Property.
This happens when I try and launch NX via Teamcenter. The error will pop up and NX never initializes. I can still launch NX independent of teamcenter with no problems, so something is going on between the communication between teamcenter and NX when trying to launch it. Anyone experienced this one before?
RE: NX Initialization Error for NX 9 Teamcenter 10
Prasanna M
In C:\TeamcenterXX\install\tem.bat
In the same directory there is a configuration.xml which MIGHT need to be edited, the file contains a line "<installinguser value= .....>
which you might need to edit.
Run the TEM and uninstall the NX integration full through.
then re-run TEM and install the NX integration.
Tomas
