Incorrect weld toe
Incorrect weld toe
I saw your comments on incorrect weld toe " Incorrect weld toe is referred in ISO welding standards..."
I wonder if you can tell me the exact name of Iso standard? Im looking for any information about weld toe geometry criteria specially in T-joint of Al.
The min and max allowable weld teo angle or radius
Tanks
Fatemeh
Tanks
Fatemeh
RE: Incorrect weld toe
ISO 5817 deals with incorrect weld toe but I do not think it is applicable to Aluminium
Welding –
Fusion-welded joints in steel, nickel, titanium and their alloys
(beam welding excluded) –
The problem with ISO is there are so many different codes/standards.
Your best bet is a Google search unless someone else on here can help you.
Cheers,
Shane
