Newer format for Universal File Dataset 55
I'm trying to import a .unv file into Femap / NX Nastran.
This .unv is basically made up of dataset 781 (nodes), 780 (elements) and 55 (initial temperature at each node).
The import kept failing completely until I "updated" formats 781 and 780, which are listed as obsolete on the SDRL page, to 2411, respectively 2412. Then all nodes and elements were imported properly.
Problem is I cannot seem to find any "newer version" of 55, which will allow me to specify the temperatures.
Any tips regarding datasets used to specify temperatures (or in general data) at nodes?
Many thanks in advance!
