How do you define the extended mass for a valve?
For seismic qualification of valves, a static side load test is performed on a valve but I am trying to find the definition of the extended mass of a valve, if someone can please help. The valve I am dealing with is a manual globe valve with bellows seal.
RE: How do you define the extended mass for a valve?
If it’s a required active valve, it’s evaluated to ensure operability after an SSE…if it’s not required to function after an SSE, it’s evaluated to ensure only structural integrity to ensure it does not interact/cause failure of a safety-related component.
