Friction hinge question
Dear Eng-tips community,
I have a question about a (presumably simplistic) friction hinge.
The assembly consists of an aluminium tube and an aluminium strip or "arm". The tube will be mounted against a wall. The arm should have complete axial freedom of movement (360°) but also stay fixed when put at an arbitrary angle. The friction of the hinge should be sufficient enough to keep the arm at a certain angle while still being able to position the arm manually. There are no other forces or loads in play. The supposed hinge is the red part in the assembly. (length of the arm is 650mm).
So My question is, is this feasable? if yes, is this (re)produceable in a (cost) efficient way? if yes, which type of materials and fittings would you recommend to start looking at?
English is not my mother-tongue so if you suspect that I am using incorrect terms, please let me know.
Kind regads
Kind regads
RE: Friction hinge question
A thru bolt with a preload spring and a couple of plastic washers would be secure and provide tension/friction adjustment.
http://www.mtfca.com/discus/messages/257047/272637...
