Repairing Weathered Phenolic Epoxy
I have someweathered phenolic epoxy coating from which rust has started coming out with a few cracks penetrating to the surface.As the first choice being an Owner, I am trying to explore the possibilities to repair from outside with out coating removal.
Do someone have some way or suggestions or having similar experience?
My last option is to blast and reapply with a coating with UV stabilizers.
Dear experts, please advise some of the possible ways.
TIA, COCO
TIA, COCO
RE: Repairing Weathered Phenolic Epoxy
Here's a potential as a fix that will hold you over. I've used this over tight rust before on steel beams and it worked great.
Andy
Dik
