catia point extraction macro help
thread560-322777: extract point position to excel
Hi everyone,
I am trying to us the script that camadian posted in the above thread (extract points to .csv). I keep getting a runtime error permission denied on line "Set data_file = filesys.CreateTextFile(file_path2, True)". I am using CATIA V5-6 RELEASE 2015 SP5 BUILD NUMBER 25. Can anyone help me out?
RE: catia point extraction macro help
what about the script in FAQ?
Eric N.
Are you sure you have permissions to save files at file_path2?
itsmyjob,
I am wanting to extract to excel so that I can import into a drawing and have what I call a live coordinate table so that if a hole location changes I can just update the table with out having to redo the entire thing. will the .txt file still do that?
JeniaL,
JeniaL,
I will have to check with my IT dept.
so I changed the drive that it saves to. now when I run the macro it completes but the excel file only shows what is under the WRITE HEADER section. Then the message box saying that the macro has finished running. its like it is skipping everything from BEGIN LOOP section and below to the end message box.
so now I inserted an axis system and made it current and get an error on "If VBA.Left(selection1.Item(i).Type, 16) = "HybridShapePoint" Then"
With this script solution, the excel/text file will not update by itself if points move...
There is a solution to have xyz of point in drawing linked with 3D but it is very time consuming to setup, it involves creating parameters in 3D for each X, Y and Z and creating drawing texts linked with 3D parameters...
I guess you should check with business and check if they need (or just want) a fully link XYZ table. I'm not saying scripting for link solution is not possible, but if it is what they need "you're gonna need a bigger boat"
Eric N.
what kind of point you have?
real 3D points? intersection points? points (not construction) in sketch? please show picture of point in Spec Tree.
Eric N.
CODE -->
If TypeName(selection1.Item(i).Value) = "HybridShapePoint" Then
Eric N.
CODE
If TypeName(selection1.Item(i).Value) = "HybridShapePointCenter" Then
Eric N.
that worked!!! thanks. is there a way for it to be in inches not mm?
CODE
data_file.WriteLine nom & ";" & myArray(0)/25.4 & ";" & myArray(1) /25.4& ";" & myArray(2) /25.4 & ";" & selection1.Item(i).Type
Eric N.
GREAT! Thanks for all your help.
