Pump for HCl 30%
Pump for HCl 30%
I need to select a Acid dosing pump (HCl 30%) for regenration of cation exchanger in demin plant. Capacity of the pump is 4300 LPH @ 5 barg discharge Pressure, we have checked for diaphragm pump with PVDF liquid end, but maximum flow per head is 2400 LPH & we need to consider double head pump, which is costly, hence please let me know if Non Metallic Sealless pump can give the desired discharge pressure as stated above. We dont want to go for metallic pump due to high cost as MOC will be Hastelloy for HCl.
RE: Pump for HCl 30%
The plastic Pumps used in this service typically never see this kind of head requirement, therefore no high pressure plastic pumps are offered for this kind of acid service
MJCronin
Sr. Process Engineer
http://www.miltonroy-europe.com/primeroyal,product...
1) Project Location
2) Intermittent/Continuous OPeration
3) Manual/Automatic control
4) Approved Vendors-API675
5) Vendor Qualifications
If we can be of assistance, please do get in touch mentioning this post on Eng-tips.
a.fenn@cdrpumps.co.uk
Cheers
Ash Fenn
www.cdrpumps.co.uk
A well phrased question has answers in itself!!!
Ash Fenn
www.cdrpumps.co.uk
