Differential Pressure Transmitter Element
Is Diaphragm is the pressure element of a Differential Pressure Transmitter (PDT)? If so then what could be the range of it?
If someone could enlighten me about this I would be very grateful.
Many Thanks
Many Thanks
RE: Differential Pressure Transmitter Element
http://www.coulton.com/beginners_guide_to_differen...
http://www.wika.us/solutions_characteristics_elect...
The sensing/measurement range of any given commercial DP transmitter is usually stamped on the ID tag, but can be decoded from a part number, where one of the digits or characters in the part number represents the differential range.
So-called "smart" transmitters can be re-ranged over a turndown range using a communications protocol, like HART.
