HVAC EVAP Coil and Condenser
Is it possible to use lower SEER Rating Evaporator coils with high seer condensing units? or Heat Pump Condenser. Is it true it may result in needing Heater Repair sooner then expected if a system is not matched with a proper SEER rating coil but it is the same Tonnage. Would it cause a system to need AC Repair as well?
John H
Service Tech
Pacific Coast Heating and AC Repair
John H
Service Tech
RE: HVAC EVAP Coil and Condenser
