I want to determine whether the con
I want to determine whether the connection I've designed will behave as a FR connection or as a PR connections
And if it is a PR connection .. how can I calculate its stiffness ?
Thanks in advance
RE: I want to determine whether the con
You're going to need to elaborate. Perhaps provide a sketch with member sizes and expected loading
I've enjoyed this paper on the basics: Link. I've only looked at PR on a couple of reno projects long ago so I'll have to rely on somebody else to fill you in on the modern code requirements etc.
