Using Spiral wound gasket to GRP pipe
In my application, I have valves connected to GRP flanges. shall I use a rubber gasket or spiral wound gasket for GRP flanges.
Thanks in advance.
Thanks in advance.
RE: Using Spiral wound gasket to GRP pipe
As LittleInch says, a "Full Face Rubber /Neoprene Gasket".
Sometimes its possible to do all the right things and still get bad results
If you do not believe us then contact the Customer Service people for GRP pipe flanges. Ask them if Full Face Gaskets are recommended.
Also look here and you will see lots of GRP Flat Face Flanges.
https://www.google.com/search?q=grp+flanges&bi...
Nathan Brink
