FEMAP API Element length
I am really beginner for APi programming.
I have to include element length inside equation.
Try to make API program that I can calculate beam/bar element buckling by use analytical method from element axial forces.
Equation where I need element length is
Nelem = (pii^2 x E x I) / elem.length^2
All other is clear, but the problem is to found correct method to included element length.
Larson HT
Larson HT
RE: FEMAP API Element length
I dont know if this will help you, but its what a figure out to measure a element length.
Sub Main
Dim App As femap.model
Set App = feFemap()
'--Create a solid
App.feSolidPrimitive(0,1,True, Array(0,0,0), Array(20, 5, 5), TEST_1)
'--Create a material
[ Dim Material_test As femap.Matl
Set Material_test = App.feMatl
Material_test.Ex = 100
Material_test.Nuxy = 0.3
Material_test.Put(Material_test.NextEmptyID())
'--Create a property
Dim Property_test As femap.Prop
Set Property_test = App.feProp
Property_test.type = FET_L_SOLID
Property_test.matlID = Material_test.ID
Property_test.Put(Property_test.NextEmptyID())
'--Mesh
App.feMeshHexSolid(-1, Property_test.ID, False, False,False,False,False, 0)
'--Get one Element
'Dim Set_Elem As femap.Elem
'Set Set_Elem = App.feElem
'Set_Elem.Get(1)
'Set_Elem.SelectID("Select your ID")
'--Get the first node of the element you want the length
Dim First_Node As femap.Node
Set First_Node = App.feNode
First_Node.SelectID("Select the first node")
'--Get the second node of the element you want the length
Dim Second_Node As femap.Node
Set Second_Node = App.feNode
Second_Node.SelectID("Select the second node")
'--Get the distance/Length between nodes
Dim VecBase As Variant
Dim vecDist As Variant
Dim Dist_bet_Nodes As Double
App.feMeasureDistanceBetweenNodes(First_Node.ID, Second_Node.ID, 0, 0, 1, VecBase, vecDist, Dist_bet_Nodes)
MsgBox "The element Legth is " & Dist_bet_Nodes
