Galloping load to gantry structure
Does anyone have experience in applying galloping load to cantilever gantry structure with horizontal arm that is carrying VMS?
According ASHTOO Code:
"Overhead cantilevered sign and traffic signal support structures shall be designed for galloping-induced cyclic loads by applying an equivalent static shear pressure vertically to the surface area, as viewed in normal elevation of all sign panels and/or traffic signal heads and backplates rigidly mounted to the cantilevered horizontal support. "
-Does that mean that load is calculated for horizontal wind direction and then that load is applied vertically?
Also in code there is statement:
"Galloping is typically not caused by wind applied to the support structure, but rather applied to the attachments to the horizontal cantilevered arm, such as signs and traffic signals."
-Does that mean that we only need to apply galloping load to attached elements, not main structure? This can significantly reduce load.
Thanks!
Milos
Thanks!
Milos
