MINIMUM EDGE DISTANCE HILTI BOLTS
LOOKING FOR CHART THAT REFLECTS EDGE DISTANCE FOR HILTI BOLTS
RE: MINIMUM EDGE DISTANCE HILTI BOLTS
You can contact Hilti at 1-800-879-8000 and request the Product Technical Guide.  This has the edge distance adjustment factors for each fastener along with a substantial amount of other technical data.
I have found that calculating allowable tension from the ACI formula for edge distance is a hair bit conservative but yields results in line with Hilti and Hillman product data.
USAC,
Try www.hilti.com and look for Hilti HAP 3.2 software. After, you download it ( it is free ), install it and you will find all you'll need about Hilti bolts distances. Also you'll be able to design connections using Hilti bolts.
CV
CV
