When to consider a beam supporting slab
Hey guys. I want to make a simiiar detailiing, however I'm confused about what do do in order to have this consideration right:
My slab shall be supported by the beam so my slab calculation would be right. What to do with the reinforcemenet in order to have such a consideration?
http://files.engineering.com/getfile.aspx?folder=4...
RE: When to consider a beam supporting slab
I cannot see a beam in this drawing.
If you are asking about how to reinforce beams, that is a very basic engineering question - perhaps ask your mentor?
Because your beam is no deeper than your slab, however, you may have problems with deflection and crack control. The beam may not be stiff enough to make your slab "feel" supported until well after significant cracking and redistribution has taken place. I'd recommend:
1) a beam at least twice as deep as your slab
2) a beam at least as deep as its span divided by 20.
3) numerical verification that beam deflections are within specified limits
Are you psychic? With the information the OP has given, how do you know the relative depths of the beam and slab?
http://files.engineering.com/getfile.aspx?folder=f...
I like the new beam depth. Reinforcing interference shouldn't be an issue in my opinion. Make some minor tweaks to the depth and the layering until everything fits.
