PAD UG-37: what thickness?
ASME VIII Div.I UG-37.
"te = thickness or height of reinforcing element"
Question: starting thickness or minimum after forming? Because in some cases are different. Thanks
RE: PAD UG-37: what thickness?
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
But Prex already answered the query. The philosophy would be the same as a rolled head. The code does not care about the nominal thickness of the plate before forming. It is solely interested in the thickness of the head (or pad) as it is welded to the vessel in its final form.
