Backpressure Calculation For Generator Radiator
Dear All,
I have to install Air Duct around a diesel generator ,
In the Generator Datasheet I found the following Data related to the radiator :
Due to site condition , I will have to install the duct as follow :
Would you please provide me method of calculation of back pressure induced by the beam structure
RE: Backpressure Calculation For Generator Radiator
Option 1: Build it and then measure it
Option 2:Use a cooling tower to cool the radiator
Option 3:Use a remote radiator
If that cannot be done add a 30* included angle fairing to the front and rear of the beam , and ignore the back pressure calculation.
l l
B.E.
You are judged not by what you know, but by what you can do.
Find a Mechanical Engineer to help with this.
If you guys can provide with Calculation example of any other Back pressure in duct systems , I will try to this myself
Thnx
