SHEAR STRESS IN RC COLUMNS
Hi everyone!
What is the best way to overcome failure of rc columns due to excessive shear under seismic loading? Normally column design is governed by axial and bending moments but in my case it is the shear stress at lower columns (first storey) that needs some attention.Any advice/idea will be appreciated much.
Thanks in advance.
Thanks in advance.
RE: SHEAR STRESS IN RC COLUMNS
2) Increase the concrete section if your design allows you to use the concrete for shear resistance.
3) Adjust your lateral system to shift some of the shear away from the problem column. Shear walls etc.
4) Add additional, reliably present precompression to the columns.
Oooh. Are you able to elaborate on how this helps, and by how much? And what does the detail look like, like a PT strand that is tensioned down the centre of the column?
Push one of your hands tightly against the other and then try to slide them past one another. Just like that. Compression usually helps frictiony situations
You'll want to consult the prestressed concrete section of your local concrete code for that. For simple friction and shear friction, the improvement in capacity basically scales up linearly with the level of compression. It's less intuitive, and less beneficial, for diagonal tension which, as you know, is usually the main concern in concrete.
Could be. It's a lot rarer in vertical elements than horizontal but some real world examples include:
1) Precast, prestressed columns.
2) Vertically post-tensioned shear wall systems.
Note that shear improvement is not the primary reason for prestressing in either of those situations. Just a side benefit.
The more common example is simply the presence of plain old dead load. Designers often don't take advantage of it because:
1) It's scary.
2) It's sometimes not allowed for seismic.
3) It's an accounting hassle.
Actually i tried to worked out for Options 1 & 2, i don't have any idea about prestressing columns, will the strands be eccentric? or will it be distributed along the periphery of columns with concrete cover? If so then how will be the main longitudinal bars be distributed/placed? Sorry really don't have any idea about columns with prestress but i'm interested about that topic, maybe will do some research. Thanks
Deker,
Thanks, yes it is part of the lateral system and will also be exposed to high axial load due to unsymmetrical framing. I will try to increase my column and check proper orientation (strong-weak axis) and see whether i can control the excessive shear due to seismic. Thanks
