Import inp VS direct job creating
Hi, I am new to this forum so forgive me if this is the wrong place to ask.
When I import this .inp-file, and create a job from it, the job submission does not work.
When I create a job directly from this .inp-file, the job gets submitted correctly.
Does anyone has an idea how I can solve this problem, so I can modify this model?
I attached the .inp-file, together with the user subroutine file (.for-file) in these links:
http://files.engineering.com/getfile.aspx?folder=b...
http://files.engineering.com/getfile.aspx?folder=4...
Thanks in advance
Max
RE: Import inp VS direct job creating
During an import A/CAE filters out all commands that are not supported in the GUI. That is reported in the message area.
You can submit a job through /CAE without importing the model. See A/CAE Manual 19.7.1 Creating a new analysis job
If you want to modify the model in /CAE, then you have to add the removed commands before submitting the job. That can be done in the Keyword Editor or the .inp file.
