soil moisture and temperature sensor
I need help finding a good soil moisture and temperature sensor. it needs to be able to work in wet soil conditions. Any help would be appreciated. A link or a way to build one would be very helpful or any other tips on the type of device. Need it for thesis
RE: soil moisture and temperature sensor
Contact a geotechnical or agricultural supply/manufacturing company.
Ok. But i will wait for a better response, hopefully
Temperature is easy, use a thermistor.
Moisture is much more difficult. I've used "soil moisture blocks" in the past. Seemed to work well at moderate moisture contents, but at best were plus or minus 2 percent.
Mike Lambert
ok, thank you. will look into that.
Foundry sand moisture content has to be measured rapidly. There are several ways. However, for years a milk bottler shaped device with dial gage on the base "speedy" meter has been used with calcium carbide mixed with sand to get a pressure that is converted to moisture content.
https://video.search.yahoo.com/yhs/search?fr=yhs-a...
Here is only one meter that is out there these days.
http://www.moisttech.com/ir3000-online-moisture-tr...
