Thread recommendation for cast Iron part
Hi dear friends and resp. seniors,
My topic is about to have ur valuable suggestions regarding thread type to be used in cast iron parts as per the application.
So basically I am working on design modification of cotton Ginning machine in which all the bolts were given earlier in BSW threads. We used it for more than 4 decades. But due to the shortage in availability and market trend of switching from BSW to metric bolts, we had also switched from BSW to metric threads and bolts. But as time goes on we faced some problems of getting thread failure in some casting parts like made up of FG200 grade. Then we analyzed the difference in both the threads of similar diameter and found that there is lot of variation in the thread height and pitch. We come to conclude that thread height and pitch in BSW threads is more as compared to same dimension Metric thread. Due to more thread height, the gripping between male and female thread is higher in BSW thread and due to more pitch, the quantity of material in two consecutive threads in more which results in more stripping strength to the threads.
I want your valuable suggestions after looking into the fact in above paragraph that which type of threads/bolts will be technically more beneficial to use specially in casting parts, after neglecting the issue of availability.
Thanks.
Thanks.
RE: Thread recommendation for cast Iron part
The closest metric thread form I can think of would be MJ type threads, which use a controlled root radius on the external threads. But this type of thread is primarily used in aerospace. Finding commercial bolts with this thread form might be difficult. Most standard fasteners also currently use a 60deg flank angle.
http://www.engineersedge.com/hardware/whitworth-sc...
https://en.wikipedia.org/wiki/British_Standard_Whi...
Perhaps rather than metric course you need to also look at metric fine, though the 60° V 55° angle may still be a issue.https://en.wikipedia.org/wiki/ISO_metric_screw_thr...
The other thing to look into is threaded inserts to reduce the stress in the cast parts. Helicoil are the obvious suggestion that springs to mind but there are other types.
Failing that you could look at custom metric thread forms or something but that would probably be unnecessary.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Sr. No Metric Threads BSW Threads
(M12X40mm) (1/2”X1,1/2")
1 Threads per Inch = 14 TPI 12 TPI
2 Pitch = 1.75mm 2.116mm
3 Thread Height = 1.074mm 1.355mm
4 Effective Pitch Dia. = 10.863mm 10.4mm
5 Basic value = Rs 3.24 Rs. 3.93
@tbuelna, I think we can not use MJ type threads coz it's a agricultural based machine in which the bolts are going to be used, as I already told it's a cotton ginning machine. As per my knowledge MJ type threads are only used in Aeronautical industry for metric
system. But beyond my knowledge could u prefer to use that in our type of machinery application..?
just a proposal: instead of discussing thread types or so, why not present the type & nature of the failures in the first place? By understanding the design environment and the specificalities of the load / loadbearing capacity issues, there might be found another solution than to fiddle with (exotic
Also, I'd stick to the standard bolt executions just following your own argumentation and rather would try to make that work.
Roland Heilmann
Lpz FRG
The failure is stripping of internal threads of part which made up of FG200 material casting. After analysis we found that it is due to the lower stripping strength of the casting material. But it has also been observed that the issue is only with metric bolts not the BSW. That is because of the higher thread height and pitch in BSW as compared to Metric threads of same dimension and material which actually results in more stripping strength in casting material.
Thanks.
What is the % of thread engagement and length of engagement in your tapped holes? If you have over 1.25D of engaged length at 70% engagement you should be getting fastener failure as a failure mode if you are using grade 5, PC 8.8 bolts. Thread stripping in a cast iron nut member that is properly designed is highly uncommon.
1) Looks like you need to take the change of thread form into account or else your stress analysis isn't given accurate results. Also as implied by Tbuelna part of the issue may be the radii reducing stress raisers.
2)
3) Do you do any NDT or other steps to ensure you have good material where the threads are going to be put? On failed threads is it good material or is there a lot of porosity or inclusions or...
Have you experimented with the taps you are using to cut the threads? Perhaps there is a fault in the particular brand of tap, or maybe they are not sharp enough. Also experiment with the process: diameter and finish of the starting hole, lubricant, and tapping speed.
What are the comments of the folks creating these tapped holes?
Have any castings with stripped holes been scrapped? As suggested by others I'd Carve out a few of the stripped holes to help understand If I was tapping cast iron or swiss cheese.
Are these new castings, that presumably are duplicates of the original parts?
Does the casting have cored holes in an effort to reduce time drilling "tap drilled" holes?
If the casting quality is mechanically poor the threads can be mighty weak.
Basically my question is about to hv the understanding about best threading system for casting parts. Will it be BSW or Metric..?
Because same thread area is getting failed in Metric system but not in BSW thread system.
Thanks.
... and BOOM! went the dynamite.
I assume the change was done as a running change in production, so now you've got a logistical mess, too. Did you change the part numbers?
The obvious solutions include going back to BSW (and making sure your dealers maintain an inventory of such at reasonable prices), or go to bigger metric bolts (adding another dimension to the logistics mess), or go to longer metric bolts (with attendant casting changes and related adjustments, probably to everything that used to clear the distal end of the bolts, or get your casting quality in order, or use thread inserts (and enlarging the bosses around the bolts and dealing with all the new clearance problems), or, or figure out the economic costs of going metric just for fun, by which time you'll be out of business anyway.
None of those obvious solutions is obviously the least awful solution, from our distant viewpoint.
An answer to Tmoose' question might be illuminative; did the threads strip at assembly, in a semi-ductile way, or did they strip in service, e.g. by fretting/corrosion?
You need to get a bunch of the stripped threads and examine them very closely.
Mike Halloran
Pembroke Pines, FL, USA
If the switch from BSW to metric was a complete changeover then it is possible the material also changed. Even if the specification is the same, often material specifications refer to minimum properties. The older material may have been stronger.
Another potential cause is one that I heard of a while back - the company changed from one plating to another and ended up with big shop-floor problems because the lubrication ability of the plating was different and no one had changed the torque requirements. Even adding lubrication or cleaning the fasteners before installation will affect the results.
unquote.
So if you are not open to any other options / improvements as proposed above by others, there's but to go back to BSW. I'd not propose to use fine metric threading with a grey cast material as you use.
However, the failure mode "after some month" together with the "stripping" could imo hint to a manufacturing issue, if one assumes subsequent failure of single arcs of the thread's helix.
The material you use is clearly out of bonds as what concerns the metric fasteners standard application range. The countermeasure against stripping is increase of the engagement length. Concluding, in order to find the required engagement length you'd need to do this whole complex set of calculations yourself. You cannot use the engagement lengths as per the standard! And pls. be aware that even now (at least around here) there's still no final jugdement given as to all of the assumptions to be made. Again, the more for this anisotrope lamellar graphite low strength cast iron.
Finally, it is still not clear to me whether you compare the 40+ ys. old BSW threaded parts (which have worked so far) with the newly manufactured metric threads, or if you compare from equal starting conditions, i. e. to newly machined BSWthreaded - parts.
Roland Heilmann
Lpz FRG
I am comparing the newly manufactured metric threads to newly machined BSW threaded - parts.
Do the fasteners fail pretty much all the time? Or, 1 in 20?
What are the metric and whitworth thread sizes in question ?
What is the loading these fasteners are subjected to? Is it one component, or fasteners of different sizes all over the machine.
I'd make sure there is not something hokey about the tap drill used, or something similar that is resulting in grossly weakened metric threads.
1 - test some finished metric holes by inserting the correct tap drill size in the finished tapped hole.
1A - install a few bolts by hand in the troublesome holes on a newly machined casting. The fasteners should go full depth by hand.
2 - confirm the correct metric fasteners are being used at assembly
3 - confirm and witness several of the metric fasteners are being installed at assembly. If there is a ton of prevailing torque, the bolts may not be clamping the component.
4 - drill and tap several test holes offset from the required holes. Torque bolts to failure and record the torque.
I am wondering what the tap drill size is and what the condition of the tapped threads are? This delayed failure mode almost sounds like loosening followed by thread wear.
What % of the ultimate failure torque of the joints in question are the bolts being tightened to? A general rule of thumb is to tighten to 60% of the failure torque and the will get you to about 75% of yield of the weakest link. Are the parts getting tightened adequately?
As Moose said- millions and millions of metric bolts are used every week into cast iron around the world without problems, if the joint is so marginal that changing the theoretical thread height from 0.640P to 0.613P pushes it into failure modes, then there was never adequate safety margin in the first place.
There must be photos available showing the assembly and the failed fasteners.
If you are producing the internal threads in your casting by tapping, one thing you might consider is using a roll forming type tap rather than a conventional cutting type tap. Roll forming taps are available in standard metric thread sizes up to about M18. Roll formed tapped threads typically provide better fatigue performance than cut threads in most materials, but I don't know about your FG200 cast iron. To use a roll forming tap, the only adjustment you might need to make is the drilled hole size.
http://balax.com/browse-products?category=7
Hope that helps.
Mike Halloran
From your original post I see that a comparison of the bolt threads was carried out and differences noted.
What I would do is work out the female shear areas of the metric and BSW threads and divide the areas into the bolt preload, that way you will obtain the shear stress the internal threads are seeing on assembly and you can compare these stresses with the allowable shear stress for the cast iron material.
I suspect that the failures are cyclic failures due to fatigue if they are failing after a period of time, maybe a fatigue analysis might help if you have data but for the moment I would calculate the above stresses and see what the stress differences are.
Ted
Tap drill 12mm.
Good catch. I checked the material requirements published by a manufacturer for using their roll form taps, and they recommended an elongation of >5%. Grey cast irons (like the FG 200 grade noted in the OP) have very low elongation characteristics and do not meet this requirement. But many types of ductile cast iron do have sufficient elongation to use roll form taps.
