Multiple Selection from Graphics Window in Assembly
I am trying to move several assembly components into a folder in the Design Tree. They are scattered throughout the Design Tree, but grouped together in the model. When I select them in the graphics window, they highlight in the Design Tree, but when I try to drag the highlighted components to the folder, I only get one component. Any suggestions would be appreciated.
V
V
RE: Multiple Selection from Graphics Window in Assembly
Isolate
Re-select the parts via window in the graphics area
Right-click in an open area of the Feature Manager
Select Create New Folder
A star for you! That is a great tip and one I can use. Even after using SWX since it came out there are still many things to learn. Thanks!
- - -Updraft
