Lifetime of a compressed gas cylinder
Hey all,
I'm working on a project that involves blanketing several reactors and storage tanks with nitrogen at a pressure of 7 psi. I've been trying to figure out how long a compressed tank will last but have had no luck. If anyone has ideas or needs more info that could help, I'd love your input.
Thanks in advance.
Thanks in advance.
RE: Lifetime of a compressed gas cylinder
You know the content of the cylinder, you can look that up.
The real question is what will the usage rate be, it depends on the leak rate of your system.
