Small threaded linear motion shaft
Hi all,
I'm a student working on a relatively simple design problem. I am looking for an off-the-shelf product that is similar to a linear motion shaft that is threaded on both sides. Examples of this kind of product can be found here
I am curious if a product exists that is similar to this, but at smaller. Ideally as small as 1/4" shaft diameter if possible.
If nothing exists, I may just machine it myself, but thought I would first try and see if anyone knows a good resource or has suggestions for this kind of part.
Matt
RE: Small threaded linear motion shaft
Length?
Lead?
Load?
Cheap example: automobile door lock motors
Mike Halloran
Pembroke Pines, FL, USA
