The component sketch shown as extracted curves on the none-master drawing view
Hi
I have an assembly with a component that consist of a sketch only (I added a sketch part as a component)
and I created a none-master drawing from this assembly
now I added a view and that sketch component is shown as extracted curves
(when cursor hover on it its show 'extracted curves')
and when I blank the component the 'extracted curves' do not blank.
Is there a setting to change this.
Thank you in advanced.
RE: The component sketch shown as extracted curves on the none-master drawing view
NX8.5
www.nxjournaling.com
Thank you for the response
Yes its on.
what its meaning and what option is recomanded.
Apparently, this setting also extracts sketch curves in the same way.
The "recommended" setting depends on the size of the files that you work with and your desired workflow. If/when you start using the newer "exact" view type, it is no longer a choice.
What you mean in using the newer "exact" view type
What are the steps to use this "exact" view type.
