i need someone to explain for me wh
i need someone to explain for me why PWM modulation its pulse duration modulation and the time of the PWM signal is constant but the width is variable
and the time in PPM signal is variable because the pulse changing its position
RE: i need someone to explain for me wh
For more information, I suggest you read Wikipedia's entriesL
https://en.wikipedia.org/wiki/Pulse-width_modulati...
https://en.wikipedia.org/wiki/Pulse-position_modul...
TTFN (ta ta for now)
Pulse Duration Modulation is a term that isn't used much. PDM has pulses of several fixed widths that are used to define the information. Morse code is an example of PDM.
Dan - Owner
http://www.Hi-TecDesigns.com
