Weight Measurement
Weight Measurement
Hi All,
i have an assembly, I want to measure weight from the end to the middle (and not the full or individual part). Please help how can measure weight up to certain length (measurement taken from corner).
Think of an assembled box, and I need to measure the weight from the corner to the middle and not the whole thing. Please help how I can do that in Solidworks.
Thanks in Advance.
Thanks in Advance.
Paul
RE: Weight Measurement
If that doesn't work for you do an Extrude Cut on the assembly. Just cut away the part you don't need.
Why do you want the weight of just a part of your assembly? Are you trying to locate the center of gravity or determine the load on a support point? Solidworks already gives you the information you need to calculate that using a free body diagram without having to cut anything.
Paul
Jon
