Pile cap reinforcement
Hey guys see the attached files. I have a pile cap. I'm designing it according to EC2. However I'm not sure about how to find the minimum reinforcement? I have a suggestion though:
I would find the minimum reinforcement for the pile cap by considering it as a deep beem therefore i will use the following formula: 0,001*t_pilecap= 0,001*800mm= 800mm^2/m
Is that correct? thanks in advance
http://files.engineering.com/getfile.aspx?folder=7...
http://files.engineering.com/getfile.aspx?folder=2...
RE: Pile cap reinforcement
Have you tried strut and tie method? I think it is appropriate method in this case, but one with more experience designing pile caps should comment.
Yes i have however i don't know what the minimum reinforcement requirement in the pile cap is.
As in any other beam or slab - min [0.0013*b*t ; 0.26*b*d*(fctm/fyk)]
