expired lube oil
expired lube oil
in our company we have a large amount of lube oil which is expired on 10/2015.
can we use this oil?
thank you
RE: expired lube oil
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
it has not been tested yet.
but we don't sure that it will be in the range in the operation.
Good luck,
Latexman
It is hard to see how an oil sitting in drums would 'go bad'.
the sample test is free because it is done in our company.
thank you everybody
If you use the oil, then replace it earlier than the standard interval: The oil is marked "Use by" 15 months ago, right? So, if the standard interval is a two-year oil lifetime, you have nine months left. If the oil has a six month lifetime, it is now 3x oil-lives old.
