Structural stability of Grating Cut out
I have requested to verify the structural stability of grating having cut-outs.
Since there are many cut-outs for pipes and cables, unusual deflection is expected between cutouts.
Can I know the design basis for this issue?
RE: Structural stability of Grating Cut out
Stability shouldn't be an issue as there's not really anything prone to buckling in Ste system. I think that your issues will be just ordinary bending and deflection based on what remains of the grating. If you post a scaled plan sketch showing the cutouts, we'll be able to offer more detailed advice.
If this is bar grating, I used to design strongbacks (sections of angle) to "header" grating openings and transfer the loads of the cut bearing bars to adjacent uncut bearing bars. Last resort is to install trimmers to carry the headers.
Several decades back I was working on some cranes that unloaded containers from ships at the Conley terminal in Boston, MA. There were outdoor walkways all around the ~100 foot level. A section of the open mesh expanded metal deck had been installed oriented the "wrong" direction. I may never forget The first time I stepped onto that section of the walk, and it sagged noticeably beneath my feet.
