How to choose Engineering materials smartly ?
I would like to know what are all the generic aspects that has to be taken into account while choosing materials? Specifically steels. There are thousands of material available in the market now with varying capabilities who's property vary from each other in one or the other way.
So, how can i choose a material specifically for my application?
It would have been great if someone could guide me through this.
RE: How to choose Engineering materials smartly ?
Unfortunately, so far i've never seen a reference that gives us complete guidance
regarding material selection, including pro-con, benefit-weakness.
On general aspect that i can share with you:
1. you need to know for what application the steel shall be used for.
2. what environment the steel shall be exposed to.
3. how the steel being loaded
4. cross check with additional specs / rules in case you have narrow down one type of steel and those steel are prohibit in certain area/application.
Another aspect, experience and research at the same field also plays an important role as a guidance.
That also become what differentiate between people who expert in material or people who merely follow the rules without knowing 'why'
or 'marketing-type' guy who can say this material is better than others without technical sound.
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Then you prioritize them (is corrosion resistance more important than weldability?)
This shortens the list greatly.
A few trials examining existing designs can act as a good exercise.
http://www.asminternational.org/home/-/journal_con...
Or if you would prefer to borrow it from a local library, you should be able to find one near you by using this link:
http://www.worldcat.org/title/metallurgy-for-the-n...
Maui
Call your local Steel Service Center.
They want you to be happy with what you buy.
Many years ago, my local Ryerson office sent over a guy who really knew his stuff.
He helped us figure out what forms to buy, and found people to weld the pieces together,
and other people to machine the welded assemblies, all at no charge beyond what we paid for the steel.
Ryerson used to give away a Stock List and an Engineering Guide, both of which were very helpful throughout my career. The last time I checked, they were selling the paperbound books for $10 each, which was probably still worth the money.
Other steel distributors can offer similar help.
They never stock everything in the Stock List, but it gives you an idea of what they might have or might be able to get.
Mike Halloran
Pembroke Pines, FL, USA
