Abaqus Load Case : Write in different files .odb
How can I manage to have my results for each loadcase in different files .odb. For example if my job is plate, to have the file plate_Loadcase1.odb, plate_Loadcase2.odb...
Thanks in advance :)
RE: Abaqus Load Case : Write in different files .odb
I think that's not possible. You would have to use scripting to generate another .odb with certain results.
If you could apply the loads in perturbation steps instead of loadcases, then you could use *Restart to do it in separate job and get separate results.
