NXopen VB dimensioning
I have a question or more regarded programming with VB in NX (journaling). I have created a single line in a sketch. My questions are the following.
How can I dimension this line using a VB program?
Is it possible to dimension the line using PMI dimensioning? If yes could you give me an example in VB?
Also is it possible to define the following line and next time when I am Journaling this line will be found by the VB program and dimensioned.?
My end goal here is to be able to import the model into the 2d drawing and have inherit all the dimensions from the sketch or for example from PMI on to the drawing view.
Thank you!
Robert K.
Thank you!
Robert K.
