Is it possible to route a condensa
Is it possible to route a condensate drain under a slab to enter into a trap primer connection for a floor drain? On a project I am working on the builder specified Adjustable on grade cleanouts Sioux Chief manufacturer 834 series for floor drains. There is a 3/4 line with a knockout for the purpose of keeping a trap primed. The AC unit is merely a 2 ton unit for a small conditioned space. Any thoughts would be appreciated . Thank you .
RE: Is it possible to route a condensa
B.E.
You are judged not by what you know, but by what you can do.
