Deformable Part
Deformable Part
Deformable Part
I am working in NX 9.
I am trying to make a part containing three solids (a prox sensor and two nuts) into a deformable part such that I can constrain the barrel prox and then deform the hex nuts to their proper position.
John Baker did a similar deformable part in this thread: thread561-355787: Expression to drive Movable Jaw on Library vise file
When I try to create the deformation, or when I try to recreate what John did in his vice, I get a series of references that do not appear in John's original vice file, and I can't figure out how to deal with these to get my deform feature to work. Are the references a new feature since the original thread?
Any suggestions would be appreciated.
Thank you!
Matt
Matt Steenwyk
Mechanical Engineer/Project Lead
Disher
www.disher.com
RE: Deformable Part
Hi Matt,
Be sure to select all features needed to create your deformable part.
Didier Psaltopoulos
http://www.psi-cad.fr
