weight transfer
weight transfer
weight transfer
To put this simply i am looking to move the motor back in a race car approx 20" keeping the motor height the same. i am curious what would my new spring rates be without testing? approx 1g corners. about 550 lbs moved back.
RE: weight transfer
Make sure they're painted either red or blue. Best I can do with the information given.
Norm
RE: weight transfer
If it's a 911, you'll need a trailer for the engine.
RE: weight transfer
Can the engine stay in the same place and just move the rest of the car forward 20 inches?
RE: weight transfer
Do you know the current weight distribution?
If so you can roughly model the shift.
Unless the car is very light (which I doubt with that heavy of engine) the change may be negligible.
