D-sub connector anchor/screw height
We use D-sub connectors on a few products we make. On one product the receptacles are mounted to a plastic plate with standard jack screws. However because of the thickness of the plastic plate the screws stick out proud of the surface of the connector shroud itself by about 0.07". Everything I've seen before has the anchors flush to the tip of the connector, or at least close. Walking around the shop and observing various D-sub connectors corroborates this. I tried to find some documentation on this but came up empty handed. Can anyone point me to a spec or standard indicating the proper relationship between the anchor and connector? Or can someone confidently say that they should be approximately flush?
Thanks!
Thanks!
RE: D-sub connector anchor/screw height
-The maximum recommended panel thickness is 0.062" (0.15 cm).
or this..
-D-Subs are designed for rear-mount applications in panels that are up to 2.0 mm thick. They come with two sets of jackscrews. One jackscrew set is 5 mm long for panel thickness up to 1.2 mm, and the other is 6 mm long for panel thicknesses from 1.2 mm, up to 2.0 mm.
or this
-Maximum recommended panel thickness is 0.078" (0.2cm).
There doesn't seem to be a "standard" that I've found before..
Z
Otherwise it looks like we'll need to either add a counterbore or use a light gauge material.
You can find it on the ASSIST website.
If you ever find yourself looking for the specification that defines almost any piece of technology you can imagine, you can probably find it there. Go there before paying IHS or SAE or ASTM any money. Chances are they bought the standard from the US military and are charging you 50$ to photocopy the data.
STF
