XYZ coordinates table
thread561-314774: Extract XYZ points from a Journal file.
Hello, I'm new here in the forum, just tried to use a some of the macros. I'm using NX8.5 with the Routing Mechanical license but I cannot get the "Bend report" with the XYZ coordinates for bending tube. Under Tools-> is no option with Bend Report.
is the problem known or is maybe problem with NX configuration?
regards
Adam
