EPAnet: FireFlow and Tower placement
I'm completely new to EPAnet and water distribution in general but was tasked with solving the placement of a new water tower for a small town (to be reviewed by someone with actual experience); however, Im having issues with testing fire flow. What is the proper way to set up my Junction for a fire flow test of 1500gpm with a duration of 2 hours? My model seems to work fine when running on regular demand but when I attempt to test fire flow I get some wildly negative pressures.
I've attached the the model and the fire flow junction I'm trying to test is the western most point.
Thank you in advance for any help!
Jameson
Jameson
RE: EPAnet: FireFlow and Tower placement
Interesting, a totally flat town sitting at sea level, all the elevations are zero
Sorry but I typically work in imperial units, so you model in SI is not intuitively obvious to me at first glance. also your post is in imperial and the model is in SI. Use one or the other
You have the pumps stacked on top of each other so you cannot see the operation of the pumps in the map, you can offset them and correct the pipe lengths for easier viewing
You have warnings that pumps that are closed because they cannot deliver heads at the times called for in the rules, I would fix the rules to get rid of the warnings. ie make like real life.
also are your pumps called by a master flow meter as the rules list? or are they called under low pressure, and secured at high pressure and/or low flow out of that pump. If so change the rules to match how the system operates. This may cause some instability as it cannot decide to run a pump or not; if so, add some short lengths of pipe complete with minor losses (minor losses are not minor near a complex set of piping) in the network between the pumps as they are in real life
Demand category
a fire is at one place not spread out over the whole town, use the demand category at the location of the proposed fire to up the flow only at that location and leave the other nodes alone again just like real life
you got your work cut out for you
Hydrae
