Flat Pattern Annotations - Re-positioning
I'm using Siemens NX11.
I've recently made a flat pattern of a sheet metal component. When I generate the flat pattern view in Drafting mode the automated annotations are generated as usual.
On components that have a lot of bends sometimes these annotations need a bit of tidying up. When I have tried to essentially drag the annotations to relocate them they simply will not move. Instead of dragging the note out of the way my curser reverts to a selection box.
I have created manual notes on the same page and they can be dragged around just fine.
Any ideas?
Chris
Chris
Mechanical Design Engineer
RE: Flat Pattern Annotations - Re-positioning
Do the annotations highlight when you mouse over them?
Do you have selection filtering set to 'Note'?
Some images or an uploaded file would help us help you.
