Conversion of Ra to Rz surface roughness
Is there any thumb rule or acceptable guidelines to convert Ra surface roughness values to Rz surface roughness values?
RE: Conversion of Ra to Rz surface roughness
There is no formal or accurate conversion as they are measuring two different characteristics. However, as a rule of thumb, I've seen factors of 8 to 10 used (multiply Ra by 8 or 10 to get Rz).
You need to get the standard out and read the definitions. I have seen the ratio between them as low as 5 and as high as 20. They are two very different characteristics.
what I propose (& do it myself all the time) is to look at this from the manufacturing, i.e. specific machine and machining p.o.v.
In the / some appropriate handbook there shall / should be tables alike this one:
which makes it possible to converse roughness values, at least for standard purposes (~ I'm located in heavy to medium mechanical manufacturing).
Additional hint: for every machining process the usual equipment is characterized by a certain achievable surface quality range. The range itself is defined by e.g. speed of machining, quality of tools,..
Ultimately, your request is a good incentive to talk to (your) workshop people winky smile
Roland Heilmann
Lpz FRG
Hi All,
Thanks for the reply. It was helpful.
