Understanding physics of this ozone injector
I visited a sugar plant last week and found myself intrigued with an ozone injector there present and did not fully understand the physics behind it. I made an sketch and attached it. They use it to kill bacteria on the sugar cane juice without using chemicals.
So basically it works like a venturi, where there is an area reduction of about 25, after the reduction of area there is a pressure reduction that creates negative gage pressure which then causes a gas (Mixture of Ozone and Oxygen) that comes from a pipe at ambient pressure to be injected.
So far so good, the thing that really intrigued me is that this piece of equipment is situated at 15 meters above the line of water at the tank, and the people there said that this was the only way to get a propper vaccum and that if the height was lower it would not work (they said they tested it), another interest fact is that the fluid inside the is kept risen 4-6 meters above the water line at the tank I also do not quite understand that, initially I thought that this was because of the negative pressure generated at the injector, but this low pressure is very localized, and the pressure a few centimeters after the area growth should already be equal to ambient pressure, what causes this?
Clearly I'm missing something, could anyone help me firgure this?
Just to provide more data, here are some parameters I could measure there
The pressure and the head of the injector is of 3,5 kgf/cm2
The sugar cane juice flow is of 100 m3/h
The gage pressure measured at the gas inlet at the injector is 8" mmHg (-0,26 bar)
The gas production is 3Nm3/min
http://files.engineering.com/getfile.aspx?folder=2...
RE: Understanding physics of this ozone injector
I think what is happening is that the restriction is simply feeding liquid into a partial vacuum caused by the fall in liquid inside the tube.
How it got to that state from a standing start is a query, but I can only assume that over time any air left in the vertical tube was swept out as fine bubbles into the tank and gradually a low pressure zone emerged which is partially fed by the gas coming in through what I imagine is quite a small nozzle??
The restriction is there to simply allow a back pressure at the top of the piping of > 1 bara to keep the liquid from creating a vacuum in the top piping.
As it then falls into the big pipe it cannot maintain pressure > 1bara as the vertical drop and increase in size means that the friction drop is less than the head of the liquid.
The level in the pipe is an indication of the amount of vacuum at the top of the pipe - 4-6 m indicates a pressure of 0.6 to 0.4 bara respectively.
Like oxygen, ozone has limited solubility and decomposes more rapidly in water than in air. This factor, along with ozone’s reactivity, requires that the ozone contactor be well covered and have multiple diffusers to maximize ozone contact with the wastewater.
However, the physics behind it is still unclear, why the need of such height? And how would one quantify the vaccum generated by the fall of the liquid?
They could have done it via a contacting tower, but this is a very "agricultural" version.
You quantify it by measuring the pressure.
At 10m high above water level the pressure at the top of a column of water which is submerged below the water level should be equal to the vapour pressure of the liquid - for cool water probably about 0.1 bara.
The pressure in your device is less as there is gas coming in and it is also a dynamic system with liquid constantly being added and vapourising caused by the spraying action.
If it works for them then it's ok. It's probably a trial and error design but there's nothing wrong in that sometimes.
They could have pressurized the ozone and injected it into a flowing pipe or small contact chamber - many different ways.
Don't think there is any physics involved. When working with a slightly soluble gas, you need a tank to dissolve the gas into solution.
The higher the level of liquid in this chamber, the greater is the dp produced by the centrifugal pump for a fixed flow (since imposed differential level is less). This increase in motive medium pressure creates a lower vena contracta region pressure. This is possibly why the vacuum pressure at the ozone nozzle is less when liquid height is reduced.
Not sure why a regular off the shelf eductor is not used here in place of this arrangement.
A venturi eductor can generate a pressure lower than atmospheric pressure- ideal for the introduction of ozone into a liquid stream to be ozonated- but only if the discharge pressure of the eductor is low enough. As you increase the discharge pressure, say by immersing the gas/liquid discharge of the venturi eductor deeper and deeper into a tank (increasing the liquid head on the discharge), you will gradually raise the suction pressure of the venturi until the point that the ozone generator can't handle it.
1) This thing is NOT a venturi as others have said.
2) the restrictor at the top would appear to be there to provide back pressure to the pump so that the section from the restriction to the pump is > 1bara at all times and hence remains a liquid
3) If the inlet where the O3 goes in was fully open, the bottom part of the tube would simply become a fall pipe with the liquid level at or very close to the tank level.
4) As you restrict the air flow entering the fall pipe, over time air will escape from the tube due to absorption in the water / small bubbles etc and hence the pressure in the tube slowly decreases. As it does so atmospheric pressure on the liquid in the tank forces it up the tube until you reach an equilibrium.
5) The benefit of being so tall is that at worst you cannot achieve a total liquid column such that it covers the inlet or reaches the restriction as 10m is the max liquid column in the tube
6) I would say someone has worked this out by trial and error as if the water flow is too high or the air flow is too high it won't work as well or at all.
