Cantilever loading
Cantilever loading
I recieved a question that I not sure how to answer. I was hoping that one of you can help me out. We have a 5.5 " OD, 3.25 I.D, 7.0 " tall porcelain bushing that has a connection on top in which a user would connect electrical cables to and the question is What is the permissible cantilever loading (lbf) on the bushings. Does this mean the max. moment applied to the bushing to prevent breakage.
thanks in advance
thanks in advance
RE: Cantilever loading
Some questions for you...
How strong is the porcelain? What is the maximum permissable stress (rupture modulus?)?
How acceptable is it for this thing to fail? Is a failure going to be an annoyance, or is it going to kill somebody?
How much control do you have over the maximum moment someone will apply to the thing? Will all access to the thing be by highly trained personnel who systematically read and follow all your documents? Will some idiot use your cantiliver loader as a chin-up bar?
How are you attaching the cables to your bushing?
The stress calculations sound simple to me unless your cable attachment is weird. The real problem is working out safety factors.
JHG
σb = (Mb * e) / I
where Mb = maximum bending moment
e = distance from neutral-axis to the outer surface
For cantilever bending, Mb = (F * L) / 2
F = applied force
L = length
I = 0.049 * (d4 - di4)
Viktor
http://viktorastakhov.tripod.com
Do you have a stub, a hole, a circumferential groove or what? What size? What is the radius of curvature where the "connection" joins the main body?
It seem to me that the stress concentration at this point, plus material properties and loading, will determine your failure.
From looking at a microstructure of porcelain (W. D. Callister, p. 423 (1997)), I suspect there is so much variability in properties (due to porosity, grain sizes of the various constituents) that only way to get properties is to contact the manufacturer. And just maybe, they will have tested a statistically significant number to failure.
Brad
