Column Link Design
Column Link Design
Hi all,
I have 3 questions regarding Column Link/Binder/Lateral Ties design (Here applicable code is BS8110).
1. What is the basis for selecting a single restraining link or an enclosed link for intermediate bars in a column when clear distance between those bars are > 150 mm?
2. Given that min bar spacing is 75 mm., how come we can have 4T12 (12mm. Bars) in a 150x150 Column (which is normative in my country). This leaves a bar spacing of 54 mm (150-(Bar:12x2)-(Cover: 30x2)-(Link 6x2)) much less than code requirement of 75 mm.
3. How to design link for Corner Column 400x400. I have seen many engineering side proposing 2 nos. Enclosed Links at right angle to each other with 4T12 at the intersection and 2T12 at each remaining corners. Please check drawing.
4 Does any one has any notes regarding design of lateral ties or links for Column?
Thanks.
Thanks.
RE: Column Link Design
I go with the single, candy cane links in almost all instances. They are much more constructable than internal Hoops in my opinion.
I coulndn't say. 150 mm here seems like a constructability problem. I try not to uses two layers of reinforcing unless my walls are at least 250 thick. Even 200 is pretty congested.
Congestion issues aside, this sounds fine. Usually the link design is based on the code minimums for longitudinal bar buckling prevention. In some cases, design is governed by shear capacity and/or ductility requirements.
