ASME 8 Div-1 tmin thickness basis for thick cylinder
Good day all,
From ASME 8 Div 1 for a cylindrical tube under internal pressure, the minimum thickness is based off the simple hoop stress equation:
S = PD/2t once the cylinder is considered thin for a particular range of t/D.
Now if the thickness exceeds that or the pressure is greater than some calculated value, the code gives a different equation:
t = R[exp(P/SE)-1]
What stress is this based on? It does not seem to fit the Lame model for thick cylinders due to the exponential function.
RE: ASME 8 Div-1 tmin thickness basis for thick cylinder
ASME PTB-1 has this equation derived in section 4.3.3. Per PTB-1, it is based on limit analysis theory using the tresca yield criterion.
Much thanks.
For the Div.1 formula, any idea on why 0.6P is taken away from SE ?
