Bath protective nylon film material
I am working on sterile disposable protection for baby bath. I need to make protective cover that will come as sterile and placed on the bath surface so it protects baby from unclean (bacterial) bath surface. I need this cover to to fit exactly (with some tolerances) to bath shape but also to be flexible and waterproof. It needs to be flexible like for example polyester bag or medical protective covers for shoes or similar. This is because it needs be packed in very small volume for distribution.
What interests me what material and technology would be best to produce this. I did a research and didn't find any complex shape and single piece plastic bags on market. All flexible plastic bags and covers are made of 2 or more flat films that are hot welded in order to produce some shape. I would like to have it in single piece. I was thinking on some cold extrusion where I would use flat nylon/polyester film and cold extrude it to required shape, but not sure is this possible. Maybe there is some other method?
The example of bath that I would put a cover:
RE: Bath protective nylon film material
I was thinking to use hot welding for silicone and adhesive to assemble complete product. Vacuum extrusion looks suitable, only concerns me can I get it to be flexible and after extrusion can I use those two approaches to assemble the product (surely it wont be easy to fit all attachments to flexible part but will work on that later).
