Drawing Stamp
Drawing Stamp
We are trying to standardize on what verbiage we use to indicate that a drawing has not been released for production. We have 8 designers whom all have there favorite.
Historically, one of the following:
PROTOTYPE
Pros - Clearly states the intended use of the part and usually, the state/phase of the design.
- More commonly used industry term?
Cons - Our culture here id to use the term "Development" for pre-production efforts. "The parts are still in Development." "These are all Dev assemblies" "This is being charged to Development"
- Vendors see "PROTOTYPE" and even if we request a volume quote for production, they feel the design is not complete and will either jack up the price or "no quote" it.
DEVELOPMENT
- Matches our cultural terminology.
Cons - A "Development" drawing could also be a drawing TYPE(a drawing delineating formed sheet metal is known as a development drawing).
- Vendors see "Development" and even if we request a volume quote for production, they feel the design is not complete and will either jack up the price or "no quote" it.
PRE-PRODUCTION
Cons - Vendors see "Development" and even if we request a volume quote for production, they feel the design is not complete and will either jack up the price or "no quote" it.
PRELIMINARY - NOT FOR PRODUCTION
Pros - This is Purchasing's preferred method.
Cons - We may also use this stamp if a drawing which has been released for production is being revised, and we send the drawing out to the vendor to gather quotes and Mfg feedback. So we could send a drawing at Rev "B", but it hasn't been released yet and is therefore considered "PRELIMINARY - NOT FOR PRODUCTION"
Thoughts?
PROTOTYPE
DEVELOPMENT
PRE-PRODUCTION
Thoughts?
Chris Wilson
Engineering Services Manager
Certified SolidWorks Professional
Certified Enterprise PDM Administrator
RE: Drawing Stamp
Why not clearly tag the drawings that have been released for production? Anything lacking the tag/stamp/signature is suspect and to not be used. As you note, there are multiple reasons they are not good.
I mark my preliminary drawings with the word "PRELIMNINARY" and the latest update date.
JHG
RE: Drawing Stamp
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: Drawing Stamp
However, a lot of suppliers are stupid. If there is nothing on a drawing to indicate otherwise they will sometimes use the version submitted for quotes instead of the one that is submitted with the contract, even if the contract specifies a particular release version.
However, the stupid doesn't end with the quote version and the same suppliers will continue using revision A after a new contract with revision B is sent to them, so no matter what one does at the outset stupid can still foul things up.
A service that Adobe used to offer was a validation server for PDFs that would allow only those with a password to open a PDF; and that password could expire, preventing anyone from opening a PDF after a certain date or that access to the PDF could be cut off entirely.
It was supposed to be used to prevent proprietary information from being leaked, but it also made sure out-of-date information could not be used.
PRELIMINARY is my general favorite, though I think IN-WORK is less typing for a similar result. Some use ONLY FOR QUOTATION if that applies, I guess to make sure the supplier doesn't send in a part with an invoice.
Any supplier is going to have a concern over the price if they are bidding on anything that isn't ready to go. An additional way to deal with that is to talk with them about the sorts of areas that are unsettled so they know how much the final document might vary from the current state. Confirm the material, the overall fabrication method, and the typical number of features and general size and anything else you can get the supplier to confirm has a large effect on the quoted price.
RE: Drawing Stamp
Everything is preliminary until it isn't. There is no significance, I can think of, between "pre-production" "prototype" and "development", as far as the drawing goes.
If your standards and processes have significant difference at 4 different statuses, I would examine whether those standards have any added value or simply added extra meaningless verbiage.
RE: Drawing Stamp
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
RE: Drawing Stamp
Ben Loosli
RE: Drawing Stamp
Now, we do have completed, safe developmental drawings. Drawing Rev level is defined as X000, then X001, then X002....X means "anything that's not production". When a part is released for production, a new drawing with rev level 000 is created. The drawing may then progress to rev 001, 002, etc.
RE: Drawing Stamp
PRELIMINARY DRAFT
THIS IS NOT A RELEASED DOCUMENT
This note is primarily intended just to cover us internally though I suspect many colleagues don't change it until deleting it for release.
If sending external I'll use either:
PRELIMINARY DRAFT
PROTOTYPE MANUFACTURE ONLY
DATE LAST MODIFIED %{Modified}
ENGINEER:
EXTENSION:
or
PRELIMINARY DRAFT
TENDER PURPOSES ONLY
The %{Modified} inserts the save date of the document in case someone forgets to increment the Rev (we have no formal control process on numeric 'prototype' revs so mistakes often occur with it being left up to individual engineers).
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
